Hi all,
I'm working on a project which holds two executable's in single controller(flashed separately), i need to switch from application to another without restarting the system, with restarting i'm able to achieve the above scenario, i need to switch without restating the system, can you guys please suggest best solution for this.
The basic approach would be to change from having two separate applications to a single application with two modes ...
Is this the same question: http://www.keil.com/forum/62256 ?
Pretty much the same comments apply.
