I have a Nuvoton NUC140 board laying around and I was trying to setup a dev environment to start some basic coding. I followed instructions under www2.keil.com/.../M0-M23 and installed 2 packs: "Nuvoton ARM Cortex-M NuMicro Family Device support" as well as "Keil MCBNUC1xx Development Board Support Package". I also installed "Blinky (MCBNUC1xx)" example and opened it in uVision. However, when I open "blinky.c" there is a reference to "NUC1xx.h" which uVision cannot resolve. I cannot find NUC1xx.h anywhere in the Keil_v5 folder. I know the header exists under "http://www.keil.com/dd/docs/arm/nuvoton/nuc1xx/nuc1xx.h" but where I am supposed to put this file? and shouldn't it be part of some sort of pack already?
This is supposed to be so easy, but I am not sure why I am running into this basic issue so early on.
Any hints would be appreciated.
Thank you, Eric
We are not maintaining this Pack (Keil: xxx_BSP) anymore and thus please get in touch with Nuvoton directly as they own these BSPs and DFPs
Thanks for the response.
I think I figured it out to some degree: looks like nuc1xxx.h was replaced by nuc100Series.h in "Nuvoton ARM Cortex-M NuMicro Family Device support" at some point. Looks like there is no consistency between Keil examples and DFP. I would imagine that whatever is accepted as a PACK would be QAed to some degree. What would be helpful is if installation path of a PAC ("Nuvoton ARM Cortex-M NuMicro Family Device support" in this example) is visible in PACK installer, otherwise I just had to explore the structure of uVision install directory in order to try to guess where the PACK is installed and which header files are available in the PACK.
