hi i want to migrate from arm compiler 5 to 6
compiler 5 uses for following local variable a register (e.g. r0) register unsigned long len;
compiler 6 does not why? which keyword should i use therefore
I advise you to look here: developer.arm.com/.../migrating-projects-from-arm-compiler-5-to-arm-compiler-6.
