1)Unit can be configured with Target Board (ADUCM360) and shows the Target Serial No and we can set the clock frequency. Set to 1MHZ to test Normal 10Mhz
2)Upon load 1st time we are getting Error -Can't access Memory
3)Upon load 2nd time- Can't enter Debug Mode-
Need help to resolve the issue.
See the below link to troubleshoot this error: http://www.keil.com/support/man/docs/ulink2/ulink2_errors.htm
Suggests that you've got code interfering with the pins used for the debug interface, or putting the device into a low power mode which turns off the logic used by the debug interface. Check if you can boot into a ROM Loader so your own code doesn't run.
The Error Messages are Generic and not helping to address our issue. Can we please get a specific reply to our issue- is it a Hardware Problem or Firmware problem??
Reset is Pulled Low and causing this issue. Does any one have Schematics of the ulink v5.1 Board and Part list to change the IC. Please let me know
Thanks Krishna.P.N.
http://scdownloader.io
Adam
The link seems to be Sound Cloud Downloader and how is it relevant to the Technical question posed?? Can you please clarify??
If the issue is still not resolved then get in touch with the technical support: www2.keil.com/.../silver
Krishna,
It is SPAM - so it is not relevant at all.
This forum has absolutely no protection whatsoever against spammers - so it frequently gets posts like that.
Keil seem to have no interest in doing anything about it.
Your topic is very great and useful for us…thank you
sites.google.com/.../
