hi i whant define function "UART0_IRQHandler" in my library ( uart library ) but i dont whant use #include <lpc17xx.h> and startup_LPC17xx.s
I tried this code but did not work void (*test) (void) = (void (*) (void)) 0x54;
in file "LPC176x/5x User manual ( UM10360 )" and "Table 50" :
Interrupt_ID : 5 Exception_Number : 21 Vector_Offset : 0x54 Function : UART0 Flag(s) : Rx Line Status (RLS) Transmit Holding Register Empty (THRE) Rx Data Available (RDA) Character Time-out Indicator (CTI) End of Auto-Baud (ABEO) Auto-Baud Time-Out (ABTO)
In a Cortex-M3 device, the Nested Vector Interrupt Controller (NVIC) and the processor core interface are closely coupled, which enables low latency interrupt processing The device handles interrupts. This coupling means that are rules that need to be followed in setting up the vector table, including the order in the table, and how to place the initial stack pointer.
See more at:
developer.arm.com/.../about-the-nvic
You can learn about the parts of a startup file here: www.keil.com/.../group__NVIC__gr.html
As a warning, if you do not use the startup file that NXP provides, you will find it harder to get help from others for using non-standard code.
If you want to write your own startup file, I suggest taking an online class about the Cortex-M architecture.
www.arm.com/.../efficient-embedded-systems
