hi i whant define function "UART0_IRQHandler" in my library ( uart library ) but i dont whant use #include <lpc17xx.h> and startup_LPC17xx.s
I tried this code but did not work void (*test) (void) = (void (*) (void)) 0x54;
in file "LPC176x/5x User manual ( UM10360 )" and "Table 50" :
Interrupt_ID : 5 Exception_Number : 21 Vector_Offset : 0x54 Function : UART0 Flag(s) : Rx Line Status (RLS) Transmit Holding Register Empty (THRE) Rx Data Available (RDA) Character Time-out Indicator (CTI) End of Auto-Baud (ABEO) Auto-Baud Time-Out (ABTO)
So why discard all the available methods? At least they were coded by people who had a grasp of what they were doing and what the processor is expecting.
i define all register and i whant define all interrupt function - i dont love use default library keil -
dif register for uart :
class UART { // Table 271 public : volatile uint32_t *RBR[4] = { // DLAB = 0, RO (uint32_t *)0x4000C000, (uint32_t *)0x40010000, (uint32_t *)0x40098000, (uint32_t *)0x4009C000 }; volatile uint32_t *THR[4] = { // DLAB = 0, WO (uint32_t *)0x4000C000, (uint32_t *)0x40010000, (uint32_t *)0x40098000, (uint32_t *)0x4009C000 }; volatile uint32_t *DLL[4] = { // DLAB = 1, R/W (uint32_t *)0x4000C000, (uint32_t *)0x40010000, (uint32_t *)0x40098000, (uint32_t *)0x4009C000 }; volatile uint32_t *DLM[4] = { // DLAB = 1 (uint32_t *)0x4000C004, (uint32_t *)0x40010004, (uint32_t *)0x40098004, (uint32_t *)0x4009C004 }; volatile uint32_t *IER[4] = { // DLAB = 0 (uint32_t *)0x4000C004, (uint32_t *)0x40010004, (uint32_t *)0x40098004, (uint32_t *)0x4009C004 }; volatile uint32_t *IIR[4] = { // RO (uint32_t *)0x4000C008, (uint32_t *)0x40010008, (uint32_t *)0x40098008, (uint32_t *)0x4009C008 }; volatile uint32_t *FCR[4] = { // WO (uint32_t *)0x4000C008, (uint32_t *)0x40010008, (uint32_t *)0x40098008, (uint32_t *)0x4009C008 }; volatile uint32_t *LCR[4] = { (uint32_t *)0x4000C00C, (uint32_t *)0x4001000C, (uint32_t *)0x4009800C, (uint32_t *)0x4009C00C }; volatile uint32_t *U1MCR = (uint32_t *)0x40010010; // Just for UART1 volatile uint32_t *LSR[4] = { (uint32_t *)0x4000C014, (uint32_t *)0x40010014, (uint32_t *)0x40098014, (uint32_t *)0x4009C014 }; volatile uint32_t *U1MSR = (uint32_t *)0x40010018; // Just for UART1 volatile uint32_t *SCR[4] = { (uint32_t *)0x4000C01C, (uint32_t *)0x4001001C, (uint32_t *)0x4009801C, (uint32_t *)0x4009C01C }; volatile uint32_t *ACR[4] = { (uint32_t *)0x4000C020, (uint32_t *)0x40010020, (uint32_t *)0x40098020, (uint32_t *)0x4009C020 }; volatile uint32_t *U0ICR = (uint32_t *)0x4000C024; // Just for UART0 volatile uint32_t *U2ICR = (uint32_t *)0x40098024; // Just for UART2 volatile uint32_t *U3ICR = (uint32_t *)0x4009C024; // Just for UART3 volatile uint32_t *FDR[4] = { (uint32_t *)0x4000C028, (uint32_t *)0x40010028, (uint32_t *)0x40098028, (uint32_t *)0x4009C028 }; volatile uint32_t *TER[4] = { (uint32_t *)0x4000C030, (uint32_t *)0x40010030, (uint32_t *)0x40098030, (uint32_t *)0x4009C030 }; volatile uint32_t *U1RS485CTRL = (uint32_t *)0x4001004C; // Just for UART1 volatile uint32_t *U1ADRMATCH = (uint32_t *)0x40010050; // Just for UART1 volatile uint32_t *U1RS485DLY = (uint32_t *)0x40010054; // Just for UART1 };
wtf - sry - see this link ( dif register for uart ) - paste.debian.net/.../
pls help me - i need define interrupt function in my project but i dont whant use this file : "startup_LPC17xx.s"
========== i define all register and clock setting and i removed "startup_LPC17xx.c" but i cant define interrupt function in my project
no person cant help me?
Until you understand what startup_LPC17xx.s does, you will not be able to add its functionality somewhere else and add your own interrupt handler routines.
fortunately, if you do use startup_LPC17xx.s, you can just write a c function with the same name as in startup_LPC17xx.s and the Default handler will be replaced with your function.
In main (or somewhere)
void UART0_HandlerIRQ(void) { your code here }
Will cause your UART0_HandlerIRQ{) function to be called every time it is activated.
You really do need to understand what startup_LPC17xx.s does before you can remove it. it is only about 250 lines. It would be helpful if you did not post again until you understand what startup_LPC17xx.s does and how you plan on making sure startup happens properly without using startup_LPC17xx.s
