I have a VCOM USB application and my intent is to send as many messages as possible to an attached PC via the VCOM serial interface. Since I am using middleware I don't have access to the traditional osWait / signal process for flow control.
So I built a queue of messages to send and in my USB application thread I have the following code to de-queue and send.
// // Write the message to USB // do { intUSBStatus = USBD_CDC_ACM_WriteData( 0U, (const uint8_t *)strCAN0, strlen( strCAN0 ) ); }while( intUSBStatus == usbDriverBusy ); // // check for error // if( intUSBStatus != strlen( strCAN0 ) ) { strCntrs2.TxErrStatus++; }
Question1 ------------- I will hang here if the usbDriverBusy stays active. Is there a safer way to pace the code... or does the RTOS guarantee to not lock up on busy.
Question 2 ------------ I don't have an osWait() call in the busy loop. Will I hog the CPU or will the RTOS take care of that?
Any pointers on the best way to pace the USBD_CDC_ACM_WriteData() would be appreciated.
Thanks, Tony
How about using callback function USBD_CDC0_ACM_DataSent that gets called when data was sent?
Thanks... dont know how I missed that!
Tony
