Hi All,
Since code memory is almost full, so i'm trying to to get some free memory through optimization.
The following settings are done:
Target -> C51 -> Code optimization - > Level: 11. Reuse common exit code Emphasis: Favor size Global register coloring (max. AJMP/ACALL): Checked Linker code packing: Checked
Warnings: Level2 Bits to round for float compare: 3 Interrupt vectors at address: 0 Enable ANSI integer promotion rules: Checked
But target is being created and shows below compilation message: Register-coloring: Linker reported a 'Address Space Overflow' error ERROR L138: CODE GENERATION: PROBLEM WHEN PROCESSING INSTRUCTIONS CAUSE: JUMP TARGET OUT OF RANGE ADDRESS: 0FC9H SEGMENT: ?PR?MAIN?MAIN
Target gets created successfully if Level: 9. Common Block Subroutines is selected.
Can somebody explain help to understand this issue?
Tool Version Numbers: Toolchain: PK51 Prof. Developers Kit Version: 9.56.0.0 Toolchain Path: C:\Keil_v5\C51\BIN C Compiler: C51.exe V9.56.0.0 Assembler: AX51.exe V3.15.0.0 Linker/Locator: LX51.exe V4.66.66.0 Librarian: LIBX51.exe V4.30.1.0 Hex Converter: OHX51.exe V1.45.0.0 CPU DLL: S8051.DLL V3.106.0.0 Dialog DLL: DCore51.DLL V2.81.5.0
Thanks!
