Hello; I'm working on STM32F446 Nucleo64, i just start use this types of hardware on Keil, so, i have a text file that contain float values, i want to read this text file and and save values in one vector and after i will apply my work on this vector, i have some questions: 1- Can i read the text file from my PC ! 2- Can i read the text file from usb ! 3- Can i upload (copy) the text file in the memory of the memory of hardware board !
What is the best way to this !! any ideas, any links !
Thanks in advance.
The Nucleo provides for a Virtual COM Port (VCP), you'd likely want to utilize this in a Terminal application to send and receive data to/from the board.
The mbed firmware in the ST-LINK provides for an MSC, but I'm not sure how you would use that to write a file to the board. The board isn't going to be able to initiate a file read on the PC.
You could perhaps use a script file to process your text file containing floats to generate a .C or .H file containing an array of floats which you could compile into your program.
