There Two programs Program A and B; Prog A is the Application Image Prog B suppost be bootload program Flow chart here: i67.tinypic.com/6o397a.png
Code for Prog A is here:
/* Includes ----------------------------------------------------*/ #include "main.h" #include "stm32l4xx_hal.h" /* Private function prototypes ----------------------------------*/ void SystemClock_Config(void); void Error_Handler(void); static void MX_GPIO_Init(void); int main(void) { /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); while (1) { HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_SET); HAL_Delay(100); HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_RESET); HAL_Delay(100); } }
Code for Prog B is here:
/* Private variables ----------------------------------------------*/ #define APPLICATION_ADDRESS (uint32_t)0x08004000 uint32_t JumpAddress; typedef void (*pFunction)(void); pFunction JumpToApplication; /* Private function prototypes ------------------------------------*/ void SystemClock_Config(void); void Error_Handler(void); static void MX_GPIO_Init(void); / int main(void) { /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { if (!HAL_GPIO_ReadPin(Button_GPIO_Port,Button_Pin)) { /* working*/ HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_SET); HAL_Delay(1000); HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_RESET); HAL_Delay(1000); }else { /* Jump to user application */ JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4); JumpToApplication = (pFunction) JumpAddress; /* Initialize user application's Stack Pointer */ __set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS); JumpToApplication(); }}}
Prog A has Memory address assigned to 0x08004000 in system_stm32l4xx.c file using #define VECT_TAB_OFFSET 0x4000 SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
After reset, when Button is Pressed MCU goes in Prog B (at 0x08000 000) and toggles LED at 1s This works fine. However when button is not pressed, MCU suppos to jump to 0x0800 4000 and run the code(Prog A) from there this doesn't seems to be working.
If you see the debug screen; i63.tinypic.com/s3giaa.png
After the line: __set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
the Value of SP changes from 0x2000 0410 to 0x2000 0408 0x2000 0408 is the value of mem address 0x08004000 and the of Prog A intial value while 0x2000 0410 is value of mem address 0x0800 0000 i.e. Prog B initial value.
Does that mean the Program jumps to 0x0800 4000 but is not running the code properly?
Just in case if the links not working then try the followings;
Flow chart here: s17.postimg.org/.../Flow.png
Debug screen here: s12.postimg.org/.../Debug_Screen.png
<AngryRant>
Oh, how I wish I had the idea of posting questions like this when I was implementing my first bootloader.
I must have been crazy, spending so much time, devising ways to acquire evidence, examining that evidence, determining what could be wrong, producing a working solution and learning so much in the process.
How was I to know that I could simply post all my code here and get someone else to sort out the issue for me?
</AngryRant>
Hi K.Paul, Thank you for the reply.
However it doesn't seem to answer/reflectthe original query. Anyway thanks and hope you have a nice day ahead!
Cross posted
my.st.com/.../Flat.aspx
Hi Clive! Brilliant! It works now.
Great help!
Regards
