Hello Here is my circuit diagram obrazki.elektroda.pl/3624808600_1477118608.jpg
Here is my program
volatile unsigned char flagSerial; volatile unsigned char flagEthernet; volatile unsigned char bitpos1; volatile unsigned char endbitpos1; volatile unsigned char stat1; volatile unsigned char SendSerial; volatile unsigned char temp; volatile unsigned char bufferu1[200]; volatile unsigned char buffer1[200]; unsigned char pc[100]; int32_t socket; uint8_t *sendbuf; uint8_t buf[8]; int main (void) { netInitialize (); USART(); NVICS(); Tim(); flagEthernet=0; flagSerial=0; bitpos1=0; SendSerial=0; stat1=0; socket = netTCP_GetSocket (tcp_cb_func); if (socket >= 0) { netTCP_Listen (socket, 3000); } while (1) { if(flagEthernet==1){ //some calculation send();flagEthernet=0;} if(flagSerial==1){ //some calculation send(); flagSerial=0;} } } uint32_t tcp_cb_func (int32_t socket, netTCP_Event event,const NET_ADDR *addr, const uint8_t *buf, uint32_t len) { switch (event) { case netTCP_EventConnect:return (1); case netTCP_EventData:flagEthernet=1;memcpy(pc, buf, len);break; } return (0); } void NVICS(void){ NVIC_InitTypeDef nvicStructure; nvicStructure.NVIC_IRQChannel = TIM2_IRQn; nvicStructure.NVIC_IRQChannelPreemptionPriority = 0; nvicStructure.NVIC_IRQChannelSubPriority = 1; nvicStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&nvicStructure); } void Tim(void){ TIM_TimeBaseInitTypeDef TimeStruct; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); TimeStruct.TIM_Prescaler=7200; TimeStruct.TIM_Period=500; TimeStruct.TIM_ClockDivision=TIM_CKD_DIV1; TimeStruct.TIM_CounterMode= TIM_CounterMode_Up ; TimeStruct.TIM_RepetitionCounter =0; TIM_TimeBaseInit(TIM2, &TimeStruct); TIM_Cmd(TIM2, ENABLE); TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); } void TIM2_IRQHandler(){ if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) { sendPC(); TIM_ClearITPendingBit(TIM2, TIM_IT_Update); } } void sendPC(void){ unsigned char i; if( netTCP_GetState(socket)==netTCP_StateESTABLISHED) { if (netTCP_SendReady (socket)) { sprintf(msg,"AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBBBBBBBBBBBBBBBCCCCCCCCCCCCCCCCCCCCCCCDDDDDDDDDDD"); for(i=0;i<150;i++) { if(msg[i]=='\0') { break; } } if (netTCP_SendReady (socket)) { sendbuf = netTCP_GetBuffer (i); memcpy (sendbuf, msg, i); netTCP_Send(socket, sendbuf,i); } } } } void send(void){ int i; for(i=0;i<150;i++){ msg[i]='\0'; } sprintf(msg,"AAAAAAAAAAAAAABBBBBBBBBBBBBBBDDDDDDDDDDDDDDDDDDEEEEEEEEEEEEEEFFFFFFFFFFF"); count1=0; SendSerial=1; USART_ITConfig(USART1, USART_IT_TXE, ENABLE); } void USART(void){ USART_InitTypeDef USAR; GPIO_InitTypeDef GPIOStruc; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); GPIO_PinRemapConfig(GPIO_Remap_USART1,ENABLE); GPIOStruc.GPIO_Mode=GPIO_Mode_AF_PP ; GPIOStruc.GPIO_Speed=GPIO_Speed_50MHz; GPIOStruc.GPIO_Pin=GPIO_Pin_6; GPIO_Init(GPIOB,&GPIOStruc); GPIOStruc.GPIO_Mode=GPIO_Mode_IN_FLOATING ; GPIOStruc.GPIO_Pin=GPIO_Pin_7; GPIO_Init(GPIOB,&GPIOStruc); USAR.USART_BaudRate=115200; USAR.USART_StopBits=USART_StopBits_1; USAR.USART_WordLength=USART_WordLength_8b; USAR.USART_Parity=USART_Parity_No ; USAR.USART_HardwareFlowControl=USART_HardwareFlowControl_None; USAR.USART_Mode=USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1,&USAR); USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); NVIC_EnableIRQ(USART1_IRQn); USART_Cmd(USART1,ENABLE); } void USART1_IRQHandler(void){ if (USART_GetITStatus(USART1, USART_IT_TXE) != RESET) { if(SendSerial==1 && count1<=150){ if(msg[count1]=='\0' ){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);SendSerial=0;return;} USART_SendData(USART1,msg[count1]); count1=count1+1; } if(SendSerial==0 || count1>=150){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);SendSerial=0;} } if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) { temp=USART_ReceiveData(USART1); if(SendSerial==1){return;} if(temp==65){ stat1=1; bitpos1=0; } else if(temp!=66 && stat1==1 && temp>47 && temp<58){ bufferu1[bitpos1]=temp; bitpos1+=1; } else if(temp==66 && stat1==1) { stat1=0; copy(); endbitpos1=bitpos1; flagSerial=1; }else if(stat1==1 && bitpos1>150){ bitpos1=0; stat1=0; }else if(bitpos1>150){ bitpos1=0; stat1=0; } } } void copy(void){ char i; for(i=0;i<100;i++){buffer1[i]=bufferu1[i];} }
Above program works fine (receive data from USART and it print data to Ethernet each 50ms very well). However after some transmission between PC to Ethernet it hangs and only I see "Hard Fault" on network bus.I think 1)when I'm in receiving mode(from PC) and Timer try to send data to PC it hangs , how can prevent from sending while we are in receiving mode?(because when I call netTCP_Send(socket, sendbuf,i); it sends all data without any control)(But I think it is be possible to send and receive simultaneously such as send and receive with USART interrupts)
2)After sending a string from pc to my device I've seen it works fine if I change this function
void send(void){ int i; for(i=0;i<150;i++){ msg[i]='\0'; } sprintf(msg,"AAAAAAAAAAAAAABBBBBBBBBBBBBBBDDDDDDDDDDDDDDDDDDEEEEEEEEEEEEEEFFFFFFFFFFF"); return; count1=0; st1=1; USART_ITConfig(USART1, USART_IT_TXE, ENABLE); }
I will appreciate for your help
return; count1=0; SendSerial=1; USART_ITConfig(USART1, USART_IT_TXE, ENABLE); }
