Hard Fault at send and receive simultaneously with USART & Ethernet
Hello
Here is my circuit diagram
obrazki.elektroda.pl/3624808600_1477118608.jpg
Here is my program
volatile  unsigned char flagSerial;
volatile unsigned char flagEthernet;
volatile unsigned char bitpos1;
volatile unsigned char endbitpos1;
volatile unsigned char stat1;
volatile unsigned char SendSerial;
volatile unsigned char temp;
volatile unsigned char bufferu1[200];
volatile unsigned char buffer1[200];
unsigned char pc[100];
int32_t socket;
uint8_t *sendbuf;
uint8_t buf[8];
int main (void)
        netInitialize ();
        USART();
        NVICS();
        Tim();
        flagEthernet=0;
        flagSerial=0;
        bitpos1=0;
        SendSerial=0;
        stat1=0;
        socket = netTCP_GetSocket (tcp_cb_func);
        if (socket >= 0) {
         netTCP_Listen (socket, 3000);
                while (1)
                        if(flagEthernet==1){
                        //some calculation
                        send();flagEthernet=0;}
                        if(flagSerial==1){
                        //some calculation
                        send();
                        flagSerial=0;}
uint32_t tcp_cb_func (int32_t socket, netTCP_Event event,const NET_ADDR *addr, const uint8_t *buf, uint32_t len) {
   switch (event) {
    case netTCP_EventConnect:return (1);
    case netTCP_EventData:flagEthernet=1;memcpy(pc, buf, len);break;
  return (0);
void NVICS(void){
    NVIC_InitTypeDef nvicStructure;
    nvicStructure.NVIC_IRQChannel = TIM2_IRQn;
    nvicStructure.NVIC_IRQChannelPreemptionPriority = 0;
    nvicStructure.NVIC_IRQChannelSubPriority = 1;
    nvicStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&nvicStructure);
void Tim(void){
TIM_TimeBaseInitTypeDef TimeStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
TimeStruct.TIM_Prescaler=7200;
TimeStruct.TIM_Period=500;
TimeStruct.TIM_ClockDivision=TIM_CKD_DIV1;
TimeStruct.TIM_CounterMode=     TIM_CounterMode_Up ;
TimeStruct.TIM_RepetitionCounter        =0;
TIM_TimeBaseInit(TIM2, &TimeStruct);
TIM_Cmd(TIM2, ENABLE);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
void TIM2_IRQHandler(){
           if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
                sendPC();
                TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
void sendPC(void){
        unsigned char i;
                        if( netTCP_GetState(socket)==netTCP_StateESTABLISHED)
                        if (netTCP_SendReady (socket))
sprintf(msg,"AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBBBBBBBBBBBBBBBCCCCCCCCCCCCCCCCCCCCCCCDDDDDDDDDDD");
                                        for(i=0;i<150;i++)
                                                if(msg[i]=='\0')
                                                        break;
                if (netTCP_SendReady (socket)) {
                sendbuf =  netTCP_GetBuffer (i);
                memcpy (sendbuf, msg, i);
                netTCP_Send(socket, sendbuf,i);
void send(void){
        int i;
        for(i=0;i<150;i++){
                msg[i]='\0';
        sprintf(msg,"AAAAAAAAAAAAAABBBBBBBBBBBBBBBDDDDDDDDDDDDDDDDDDEEEEEEEEEEEEEEFFFFFFFFFFF");
        count1=0;
        SendSerial=1;
        USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
void USART(void){
        USART_InitTypeDef USAR;
        GPIO_InitTypeDef GPIOStruc;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap_USART1,ENABLE);
        GPIOStruc.GPIO_Mode=GPIO_Mode_AF_PP ;
        GPIOStruc.GPIO_Speed=GPIO_Speed_50MHz;
        GPIOStruc.GPIO_Pin=GPIO_Pin_6;
        GPIO_Init(GPIOB,&GPIOStruc);
        GPIOStruc.GPIO_Mode=GPIO_Mode_IN_FLOATING ;
        GPIOStruc.GPIO_Pin=GPIO_Pin_7;
        USAR.USART_BaudRate=115200;
        USAR.USART_StopBits=USART_StopBits_1;
        USAR.USART_WordLength=USART_WordLength_8b;
        USAR.USART_Parity=USART_Parity_No ;
        USAR.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
        USAR.USART_Mode=USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART1,&USAR);
        USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
        NVIC_EnableIRQ(USART1_IRQn);
        USART_Cmd(USART1,ENABLE);
void USART1_IRQHandler(void){
        if (USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
                        if(SendSerial==1 && count1<=150){
                        if(msg[count1]=='\0' ){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);SendSerial=0;return;}
                        USART_SendData(USART1,msg[count1]);
                        count1=count1+1;
                        if(SendSerial==0 || count1>=150){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);SendSerial=0;}
if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        temp=USART_ReceiveData(USART1);
        if(SendSerial==1){return;}
        if(temp==65){
        stat1=1;
        bitpos1=0;
        else if(temp!=66 && stat1==1 && temp>47 && temp<58){
        bufferu1[bitpos1]=temp;
        bitpos1+=1;
        else if(temp==66 && stat1==1)
        stat1=0;
        copy();
        endbitpos1=bitpos1;
        flagSerial=1;
        }else if(stat1==1 && bitpos1>150){
                bitpos1=0;
                stat1=0;
        }else if(bitpos1>150){
                bitpos1=0;
                stat1=0;
void copy(void){
        char i;
        for(i=0;i<100;i++){buffer1[i]=bufferu1[i];}
