Can't step through .s assembly file when debugging
I've done some searching on the forum, and this question seems to be asked, but no concrete answer has been given.
I'm using the Tiva C with the latest uVision. I have a main.s where all my assembly code is located. When I try to debug, it steps through my startup file, but when it branches to my asm file, it will not jump to it. Even when I set breakpoints in the main.s, it only shows the line in the disassemly window.
Thanks for your help!
