Hello, i have problem with jansson pack. when i run the example code in simulator its output is correct as expected but when i change the device to for example stm32f103 the output is empty curly brackets {}; the example code is :
void add_2array_to_json( json_t* obj, const char* name, const int* marr, size_t dim1, size_t dim2 ) { size_t i, j; json_t* jarr1 = json_array(); for( i=0; i<dim1; ++i ) { json_t* jarr2 = json_array(); for( j=0; j<dim2; ++j ) { int val = marr[ i*dim2 + j ]; json_t* jval = json_integer( val ); json_array_append_new( jarr2, jval ); } json_array_append_new( jarr1, jarr2 ); } json_object_set_new( obj, name, jarr1 ); return; } void SystemClock_Config(void); static json_t* jdata; int main() { char* s; int arr1[2][3] = { {1,2,3}, {4,5,6} }; int arr2[4][4] = { {1,2,3,4}, {5,6,7,8}, {9,10,11,12}, {13,14,15,16} }; char ss[128]; /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_DMA_Init(); MX_USART1_UART_Init(); json_object_seed(1); jdata = json_object(); add_2array_to_json( jdata, "arr1", &arr1[0][0], 2, 3 ); add_2array_to_json( jdata, "arr2", &arr2[0][0], 4, 4 ); s = json_dumps( jdata, 0 ); HAL_UART_Transmit(&huart1,(uint8_t*)s,strlen(s),1000); // puts( s ); free( s ); json_decref( jdata ); while(1){ HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_13); HAL_Delay(200); }; }
i used jansson v2.7 and also the latest v2.9. both the same am i wrong?
Hello could you tell me please whats your library that used and how can i use that in my project is there any tutorial ? i want to make a project to send json data with udp. best regards
