Sorry just trying to set up the Keil system to run a simple starter program with an STM32F051. Used STM32Cube to get the code set up, ported over to the Keil uVision tool. When I go to compile I get the following. It doesn't seem to find the path but can't figure out why
Any help? *** Using Compiler 'V5.06 update 2 (build 183)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'ST_blink' compiling stm32f0xx_it.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_it.__i'. compiling stm32f0xx_hal_msp.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_msp.__i'. compiling main.c... Fatal error: C3906U: Malformed via file 'st_blink\main.__i'. compiling system_stm32f0xx.c... Fatal error: C3906U: Malformed via file 'st_blink\system_stm32f0xx.__i'. compiling stm32f0xx_hal_tim.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_tim.__i'. compiling stm32f0xx_hal_i2c.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_i2c.__i'. compiling stm32f0xx_hal_dma.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_dma.__i'. compiling stm32f0xx_hal_cortex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_cortex.__i'. compiling stm32f0xx_hal_pwr.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_pwr.__i'. compiling stm32f0xx_hal_tim_ex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_tim_ex.__i'. compiling stm32f0xx_hal.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal.__i'. compiling stm32f0xx_hal_rcc.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_rcc.__i'. compiling stm32f0xx_hal_flash.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_flash.__i'. compiling stm32f0xx_hal_i2c_ex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_i2c_ex.__i'. compiling stm32f0xx_hal_gpio.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_gpio.__i'. compiling stm32f0xx_hal_pwr_ex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_pwr_ex.__i'. compiling stm32f0xx_hal_rcc_ex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_rcc_ex.__i'. assembling startup_stm32f051x8.s... startup_stm32f051x8.s: error: A3906U: Malformed via file 'st_blink\startup_stm32f051x8._ia'. compiling stm32f0xx_hal_flash_ex.c... Fatal error: C3906U: Malformed via file 'st_blink\stm32f0xx_hal_flash_ex.__i'. "ST_blink\ST_blink.axf" - 1 Error(s), 0 Warning(s). Target not created.
Rename your project folder to an ascii only name, for example 'ABC', then try it again.
