Hi all... I have a very small issue.... i have written a code to send messages through SIM800 using SST89E516RD2 microcontroller. code is:-
#include <sst89e516rd2.h> sbit row0=P2^4; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^7; sfr COL=0xA0; unsigned char *message = "Hi Everybody "; // Content of the message to be sent int keypad(); void sendsms(); void puts(unsigned char* ptr); void putc(unsigned char chr); void initialize(); unsigned char CTRLZ = 0x1A; unsigned char xdata phoneno[10]; //Array to store the phone no. void main() // MAIN STARTS HERE { unsigned int i,j; while(1) { for(j=0;j<10;j++) { phoneno[i]=keypad(); // Entering new company phone no LCD_putc(phoneno[i]); i++; } i=0; initialize(); msdelay(1000); sendsms(); } } void sendsms() { puts("ATE0\r"); msdelay(1000); puts("AT\r"); msdelay(1000); puts("AT+CMGF=1\r"); msdelay(1000); puts("AT+CMGS=\""); puts(phoneno); puts("\""); puts("\r"); msdelay(1000); puts(message); msdelay(1000); putc(CTRLZ); } int keypad() { unsigned char dat[4][4]={'1','2','3','A', // assigning key matrix '4','5','6','B', '7','8','9','-', '*','0','#','+', }; unsigned char colloc,rowloc; COL=0xFF; row0=0; row1=0; row2=0; row3=0; while(1) do { row0=0; row1=0; row2=0; row3=0; colloc=COL; colloc&=0x0F; } while(colloc!=0x0F); do { do { msdelay(10); colloc=COL; colloc&=0x0F; } while(colloc==0x0F); msdelay(10); colloc=COL; colloc&=0x0F; } while(colloc==0x0F); while(1) { row0=0; row1=1; row2=1; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=0; break; } row0=1; row1=0; row2=1; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=1; break; } row0=1; row1=1; row2=0; row3=1; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=2; break; } row0=1; row1=1; row2=1; row3=0; msdelay(5); colloc=COL; colloc&=0x0F; if(colloc!=0x0F) { rowloc=3; break; } } if(colloc==0x0E) return(dat[rowloc][0]); else if(colloc==0x0D) return(dat[rowloc][1]); else if(colloc==0x0B) return(dat[rowloc][2]); else return(dat[rowloc][3]); } } void puts(char* p) { char *temp = p; /*temp pointer so that the actual pointer is not displaced */ while(*temp != 0x00) { putc(*temp); temp++; } } void putc(unsigned char chr) { SBUF = chr; while(TI==0); /*Wait until the character is completely sent */ TI=0; /*Reset the flag */ } // MAIN ENDS HERE void initialize() { SCON = 0x50; /*SCON: mode 1, 8-bit UART, enable receive */ TMOD |= 0x20; /*TMOD: timer 1, mode 2, 8-bit */ TH1 = 0xFD; /*TH1: for 9600 baud */ TR1 = 1; /*TR1: timer 1 run */ } void msdelay(unsigned int value) { unsigned int i,j; for(i=0;i<value;i++) for(j=0;j<100;j++); }
Now my problem is when i change unsigned char Xdata phone[10]; to unsigned char phoneno[10]; i GSM module send me the messages... but if i write unsigned char Xdata phoneno[10]; the GSM modem does not send any messages. the system only works and sends messages when array phoneno[10] is stores in DATA instead of XDATA. why does this happen.... can you please help me....
How many places are you cross-posting to?
www.edaboard.com/thread358173.html
"the GSM modem does not send any messages"
So - have you configured the processor so that XDATA will access the RAM available in the chip, instead of trying to access any external RAM connected outside of the processor?
Sorry for that.... But how should i configure the processor... Can you please give me any idea....
And also i have created many other arrays which i store in xdata and which i can access it without configuring the processor. I Also have xdata arrays which store passwords and then the same password are again used to store the datas like RTC date and time to eeprom without configuring the processor.... So how does they work.
I am not using any external xdata. The controller i am using has an internal xdata memory. I am using the same.
Yes, the processor has internal XDATA - but is it configured to use this RAM? There is a configuration register where one bit decides if XDATA accesses will use this internal RAM or if it will perform external accesses.
But how can i canfigure that.... Any notes for that...????
"But how can i canfigure that...."
Are you saying that the chip manufacturer hasn't documented the configuration registers for the processor???
