LPC1850 - soft reset - SPIFI Boot - KEIL UV5 RTX
My system is a LPC1850 with IDE KEIL UV5 RTX and I boot from SPIFI. That being
said I am trying to do a soft reboot. My hardware is set and I do not have an
external pull-up P2-7.
I have tried;
*(volatile unsigned int *)0x40043100 = 0x10400000; //memmap with boot ROM address
*(volatile unsigned int *)0x40053100 =(1<<0); // Core reset
But I suspect since I don't have a pull up on P2-7 this will not work.
Do I need to update the OTP? If so, I cant seem to find a function in the Keil IDE.
I sure could use your help! Thanks.
