Hi, I'm using Keil MDK ARM 5.20.
I currently moved to Keil so I'm new to this tool. Before this change, I used IAR EWARM.
The IAR EWARM had these useful features; "Find All References to "foo"", "Find All Calls to "foo"", "Find All Calls from "foo"", where "foo" can be a variable or a function.
These features allowed the users to check whether a function is called in which line and which source file.
Similar to this, does Keil uVision 5 suppoorts similar features?
-Best Regards, David
Well there is "Find in File(s)" which is quite effective.
The linker also generates an HTML file with functions broken down, and each having a "Called By", and a Static Analysis of the generated application.
There are right-click menu options to go to definitions and references, though they are less than ideal.
Thanks for the tip about "Find in File(s)". It is quite effective.
"The linker also generates an HTML file" - Where can I find this?
By the way, my project settings - Listing has Assembler Listing, Linker Listing : \Listing\xxx.map Memory Map, Symbols, Size Info, Callgraph, Cross Reference, Totals Info, Unused Sections Info, Veneers Info checked and project settings - Linker has Use memory Layout from Target Dialog, Report "might fail" Conditions as Errors checked.
Should be in the output directory as FOO.HTM, along with FOO.AXF and FOO.MAP
