Hiya,
I have a uLink pro and can successfully see the instruction trace (derived from the ETM data) of a target in uVision in the Trace Data window. However, I'm interested in seeing the raw ETM data extracted from the target chip (i.e., A-sync and I-sync packets as defined in chapter 7 of infocenter.arm.com/.../IHI0014Q_etm_architecture_spec.pdf).
Is there any way to expose this information or infer it without error? If so, how?
Thanks so much!
Googling "cmsis dap etm trace" found this:
https://github.com/TheShed/OpenOCD-CMSIS-DAP/blob/master/src/target/etm.c
/* * ARM "Embedded Trace Macrocell" (ETM) support -- direct JTAG access. * * ETM modules collect instruction and/or data trace information, compress * it, and transfer it to a debugging host through either a (buffered) trace * port (often a 38-pin Mictor connector) or an Embedded Trace Buffer (ETB). * * There are several generations of these modules. Original versions have * JTAG access through a dedicated scan chain. Recent versions have added * access via coprocessor instructions, memory addressing, and the ARM Debug * Interface v5 (ADIv5); and phased out direct JTAG access. * * This code supports up to the ETMv1.3 architecture, as seen in ETM9 and * most common ARM9 systems. Note: "CoreSight ETM9" implements ETMv3.2, * implying non-JTAG connectivity options. * * Relevant documentation includes: * ARM DDI 0157G ... ETM9 (r2p2) Technical Reference Manual * ARM DDI 0315B ... CoreSight ETM9 (r0p1) Technical Reference Manual * ARM IHI 0014O ... Embedded Trace Macrocell, Architecture Specification */
So maybe that's worth a look ... ?
