Error while Downloading code in ext. flash
I'm using an AT91SAM9X35 controller.i wanted to load a application code in evaluation board through Download option(i.e in flash ), but i'm getting an below error.i'm using an ATMEL SAM-ICE DEBUGGER to load the code.
Load "C:\\Users\\Tejas\\Desktop\\blinky_led\\Blinky\\Int_RAM\\Blinky.axf"
ProjectFile = C:\Users\Tejas\Desktop\blinky_led\Blinky\JLinkArm_SAM9X35 Int RAM.ini
Device = SAM9X35
Info: Device "AT91SAM9X35" selected (0 KB flash, 0 KB RAM).
VTarget = 3.313V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32)
Info: Cache type: Separate, Write-back, Format C (WT supported)
DLL version V4.62, compiled Jan 25 2013 15:19:47
Firmware: J-Link ARM V8 compiled Aug 26 2015 15:08:21
Hardware: V8.00
Hardware-Breakpoints: 2
Software-Breakpoints: 8192
Watchpoints: 0
Found 1 JTAG device, Total IRLen = 4: Id of device #0: 0x0792603F
ARM9 identified.
JTAG speed: 1000 kHz
Using adaptive clocking instead of fixed JTAG speed.
No Algorithm found for: 00000000H - 0000065FH
Erase skipped!
