Hi all,
I encounter a problem with uVision 5.23 and Hitex emulator (Tanto2) on a Win10 laptop (fresh install). What i can do: - start UV5, open my project, - start a debug session on emulator, load my project, make a first run and stop debug session.
The problem appears when I want to start a second debug session on emulator. On ce I click on the Start Debug, UV5 crashes with this message: uVision IDE has stopped working A problem caused the program to stop working correctly....
I need to launch again UV5, which loses my current project, to run a new debug session. The emulator is working fine on the laptop of my colleague (same release of UV5, same SDK, same project). Moreover, the emulator is up-to-date, i reflashed the firmware today.
If you have some advice or an idea about the root cause of this problem, i hear you?
Thank you in advance for your help.
no, there is not such plan yet
