USBD_HID_GetReportTrigger problem: works only once
I am writing USB HID Device driver for ARM M0+ and got a problem with sending data from device to host. The device can send data only on the first call of USBD_HID_GetReportTrigger(). The all others calls of USBD_HID_GetReportTrigger() does nothing, it does not call back ARM_USBD_EndpointTransfer(). If I directly call ARM_USBD_EndpointTransfer(0x81, &but, 1) from main() then device can send data to host as many times as requested, no problem. I can see in memory two bits of difference in MDK usbd_config_0.o module (one is in usbd0_data->endpoint_active[17] and another looks like in usbd_driver_semaphore_cb_mem). If clear those two bits in MDK memory after USBD_HID_GetReportTrigger() got stuck then USBD_HID_GetReportTrigger() can call ARM_USBD_EndpointTransfer() again.
