C++ global object multiple defined
Hello:
I'm coding in C++ for ARM for the first time, using Keil. I'm working in a project that already exists but I need to make some changes. I cannot change the libraries or the file's structure. The test_1 and test_2 functions use a global object and I cannot change it. Problem is, the code was created to run each test in an independent compilation, but now I need to create a menu for all the tests in a single project.
I'm having problems with the use of a global object. I want to instantiate one object in a .cpp file and use it in another .cpp file (using extern), but linker keep sayng that the object was multiple defined.
Any idea how to solve it?
Thanks.
---My project:
Library File:
// myclass.h:
class myclass{
Header for tests 1
// test_1.h
#ifndef TST1_H
#define TST1_H
void test_1(void);
extern myclass mc(0);  // extern declaration
#endif
Tests file 1
//test_1.cpp
#include "my_lib.h"
#include "test_1.h"
myclass mc(0);
void test_1(void){
mc.func1();
mc.func2();
Header for tests 2
// test_2.h
#ifndef TST2_H
#define TST2_H
void test_2(void);
#endif
Tests file 2
//test_2.cpp
#include "my_lib.h"
#include "test_2.h"
void test_2(void){
mc.func1();
mc.func2();
Main cpp file
// main.cpp
#include "my_lib.h"
#include "test_1.h"
#include "test_2.h"
void main(void){
// menu for tests...
case 1: test_1(); break;
case 2: test_2(); break;
