LPC1837 USB Middleware Signed Driver
Hello, I have a board using the Keil Middleware USB device software. The included driver is mcb1800-vcom.inf DriverVer=05/13/2013,5.3.0.0 Is there a newer version available that is signed? I'm using Windows 7 Embedded, and none of the usual workarounds have worked to get around having an unsigned driver, I have to press F8 at every boot. Thanks!
  • Hi Matthew,
    I have tried this on Windows 7 Enterprise, and driver is installed without problems.
    Searching the web shows there are such problems with Windows 7 Embedded, as this seems to be somewhat different version of Windows.
    Can you try same thing on Windows 7 not the Embedded version?
    Which version of Windows 7 Embedded are you using?
    Best regards, Milorad
  • Hi Matthew,
