A51 Problem Error #4 line 1 without details
hello,
it is my first step with AT89C2051 try to assemble this program
with A51 assemble ..
and at 1srt comile i get 5 erros,
i corrected one, wich what clearly indicated in the *.lst result.
But they are 3 remainings errors
Error 4 Line 1
Nothing suspect (by me !) inside the *.lst result .
So , i request an advice from specialist ..
what could be thoses errors ?
; date 30.01.2018
; correction error ligne 233
; removedall comments (because size over 7000cars)
   ORG 0000H
JMP START
    ORG 0003H
RETI
     ORG 000BH
LJMP INTT0
     ORG 0013H
RETI
     ORG 001BH
LJMP INTT1
     ORG 0023H
RETI
;  Main procedure
START:
   MOV R0,#70H ;
   MOV R7,#0BH ;
CLEARDISP: MOV @R0,#00H ;
INC R0 ;
DJNZ R7,CLEARDISP ;
MOV 20H,#00H
MOV 7AH,#0AH
MOV TMOD,#11H
MOV TL0,#0B0H
MOV TH0,#3CH
MOV TL1,#0B0H
MOV TH1,#3CH
SETB EA
SETB ET0
SETB TR0
MOV R4,#14H ;
START1: LCALL DISPLAY ;
JNB P3.7,SETMM1 ;
SJMP START1 ;
SETMM1: LJMP SETMM ;
;  Timing procedure of one second
INTT0: PUSH ACC
PUSH PSW
CLR ET0
CLR TR0
MOV A,#0B7H
ADD A,TL0
MOV TL0,A
MOV A,#3CH
ADDC A,TH0 ;
MOV TH0,A
SETB TR0
DJNZ R4, OUTT0
ADDSS:
MOV R4,#14H
MOV R0,#71H
ACALL ADD1 ;
MOV A,R3
CLR C
CJNE A,#60H,ADDMM ;
ADDMM: JC OUTT0
ACALL CLR0
MOV R0,#77H
ACALL ADD1
MOV A,R3
CLR C
CJNE A,#60H,ADDHH ;
ADDHH: JC OUTT0
ACALL CLR0
MOV R0,#79H
ACALL ADD1
MOV A,R3
CLR C ;
CJNE A,#24H,HOUR ;
HOUR: JC OUTT0
ACALL CLR0
OUTT0: MOV 72H,76H
MOV 73H,77H
MOV 74H,78H
MOV 75H,79H
POP PSW
POP ACC
SETB ET0
RETI
;      Flicker the procedure while adjusting-
INTT1: PUSH ACC
PUSH PSW ;
MOV TL1, #0B0H
MOV TH1, #3CH ;
DJNZ R2,INTT1OUT
MOV R2,#06H
CPL 02H
JB 02H,FLASH1
MOV 72H,76H
MOV 73H,77H
MOV 74H,78H
MOV 75H,79H
INTT1OUT: POP PSW
POP ACC ;
RETI ;
FLASH1:
JB 01H,FLASH2
MOV 72H,7AH
MOV 73H,7AH
MOV 74H,78H
MOV 75H,79H
AJMP INTT1OUT
FLASH2: MOV 72H,76H
MOV 73H,77H
MOV 74H,7AH
MOV 75H,7AH ;
AJMP INTT1OUT
;  Add a sub procedure
ADD1:
MOV A,@R0
DEC R0
SWAP A
ORL A,@R0
ADD A,#01H
DA A ;
MOV R3,A
ANL A,#0FH
MOV @R0,A
MOV A,R3
INC R0
SWAP A
ANL A,#0FH
MOV @R0,A
RET
;  Zero clearing procedure
CLR0:
CLR A ;
MOV @R0,A
DEC R0
MOV @R0,A
RET
;   The clock adjusts the procedure
SETMM:
cLR ET0
CLR TR0
LCALL DL1S
JB P3.7,CLOSEDIS
MOV R2,#06H
SETB ET1
SETB TR1
SET2: JNB P3.7,SET1
SETB 00H
SET4: JB P3.7,SET3
LCALL DL05S
JNB P3.7,SETHH
MOV R0,#77H
LCALL ADD1
MOV A,R3
CLR C
CJNE A,#60H,HHH
HHH: JC SET4
LCALL CLR0
CLR C
AJMP SET4
CLOSEDIS: SETB ET0
SETB TR0
CLOSE: JB P3.7,CLOSE
LCALL DISPLAY
JB P3.7,CLOSE
WAITH: JNB P3.7,WAITH
LJMP START1
SETHH: CLR 00H
SETHH1: JNB P3.7,SET5
SETB 01H
SET6: JB P3.7,SET7
LCALL DL05S
JNB P3.7,SETOUT
MOV R0,#79H
LCALL ADD1 ;
MOV A,R3 ;
CLR C ;
CJNE A,#24H,HOUU
HOUU: JC SET6
LCALL CLR0
AJMP SET6
SETOUT: JNB P3.7,SETOUT1
LCALL DISPLAY
JNB P3.7,SETOUT
CLR 01H
CLR 00H
CLR 02H
CLR TR1 ;
CLR ET1
SETB TR0
SETB ET0
LJMP START1
SET1: LCALL DISPLAY
AJMP SET2
SET3: LCALL DISPLAY
AJMP SET4
SET5: LCALL DISPLAY
AJMP SETHH1
SET7: LCALL DISPLAY
AJMP SET6
SETOUT1: LCALL DISPLAY
AJMP SETOUT
;   Reveal the procedure
DISPLAY: MOV R1,#70H ;
MOV R5,#0FEH
PLAY: MOV A,R5
MOV P3,A
MOV A,@R1
MOV DPTR,#TAB
; MOVC A,@ADPTR ; Check that reveals the data correspond to one section of codes   <--  5 ERRORs
; ERROR A4
; A51: ERROR 4 (BAD INDIRECT REGISTER IDENTIFIER)
;This indicates that the register or register combination is not valid for indirect access.
; For example, @R7, @R3, @PC+A, @DPTR+A. <- ????
MOVC A,@A+DPTR  ; Check that reveals the data correspond to one section of codes   <--- 3 errors
MOV P1,A ;
LCALL DL1MS
INC R1 ;
MOV A,R5
JNB ACC.5,ENDOUT
RL A ;
MOV R5,A
AJMP PLAY ;
ENDOUT:
 SETB P3.5
MOV P1,#0FFH
RET
TAB: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H,0FFH
; One section of code tables of male genital altogether
; †0″ †1″ †2″ †3″ †4″ †5″ †6″ †7″ †8″ †9″ †Non- bright â€
;  Time delay procedure
DL1MS:
MOV R6,#14H
DL1: MOV R7,#19H
DL2: DJNZ R7,DL2
DJNZ R6,DL1
RET
DS20MS: ACALL DISPLAY
ACALL DISPLAY
ACALL DISPLAY
RET
DL1S: LCALL DL05S
LCALL DL05S
RET
DL05S: MOV R3,#20H
DL05S1: LCALL DISPLAY
DJNZ R3,DL05S1
RET
END
message on MDOS windows ( i used DOSBOX 0.74 to use AR1.EXE) inside WIN10
MS-DOS Macro assembler A51 V4.4
Object module palced in clock.obj
Assembler invoked by : A51 clock.asm
ASSEMBLER COMPLETE 3 ERRORS Found
nota: i can't join the *.lst , because more > 7000 cars
is it possible to joint a file (clock.lst) ?
