KEIL long jump
Hello
How can i instruct keil to use BLX instruction instead of BL.W while calling functions ?
any compiler settings ?
I need to call a function which is there in flash from ram code. Thanks.
  • ; Reset handler
    Reset_Handler    PROC
                     EXPORT  Reset_Handler             [WEAK]
            IMPORT  SystemInit
            IMPORT  __main
                     BL.W    SystemInit ; Relative
                     LDR     R0, =SystemInit
                     BLX     R0 ; Anywhere in 4GB space
                     LDR     R0, =__main
                     BX      R0
                     ENDP
        Reset_Handler
            0x00000000:    f7fffffe    ....    BL       SystemInit
            0x00000004:    4806        .H      LDR      r0,[pc,#24] ; [SystemInit = 0x20] = 0
            0x00000006:    4780        .G      BLX      r0
            0x00000008:    4806        .H      LDR      r0,[pc,#24] ; [__main = 0x24] = 0
            0x0000000a:    4700        .G      BX       r0
    Fixup the relative form based on the address you use, or use a PC relative form to load a literal into a register and use that. Use a jump table with absolute addresses.
    Generally best to keep all the code you want in RAM so as not to touch FLASH. Or use an attribute/pragma to push the functions you want in RAM into a section your describe in RAM via the scatter file load region.
