LPC11U68 ADC read value oscillates
does anybody have an example code of using ADC of NXP LPC11U68? I have a very oscillating output even if I use battery supply or add additional capacitor. The filter capacitors on VREFP and VREPN are used as defined in Product datasheet. Besides how do I enable sequence B? If I try the same procedure as by sequence A nothing is converted. My code is below.
#define SETBIT(X, Y) (X |= 1 << Y)
#define CLEARBIT(X, Y) (X &= ~(1 << Y))
int main(void)
{ // Variables char cText[20]; unsigned long ulVal;
// System init targetInit();
// LCD init LCD_Init();
// SETTING OF ADC, channel 1 // Function 1 - ADC, channel 1 PIO0_23 = 1;
// Analog mode for pi CLEARBIT(PIO0_23,7);
// Enable CLK for ADC SYSAHBCLKCTRL |= 1 << 13;
// Enabling power for ADC, bit 4 to 0 CLEARBIT(PDRUNCFG,4);
// Autocalibration AD_Self_calibration();
// The conversion clock is equal to system clock AD_CTRL &= ~(0x000000ff);
// In sequence A set to sample channel 1 SETBIT(AD_SEQA_CTRL,1);
// Enable sequence A SETBIT(AD_SEQA_CTRL,31);
// First line of LCD LCD_Write_string(" AD value ");
// Cursor to second line LCD_Set_position(2,1);
// Second line of LCD LCD_Write_string(" U = 0000 mV ");
while(1) { // Start of conversion AD_SEQA_CTRL |= (1<<26);
// Waiting to finish conversion while(CHECKBIT(AD_DAT1,31)==0);
// Reading DAT register ulVal = AD_DAT1;
// Extrude the proper value ulVal = (ulVal >> 4);
// Extrude the proper value ulVal = ulVal & 0x0FFF;
// Calculation ADC value in mV ulVal = 1000*VREF*ulVal/4095;
// Cursor to second line LCD_Set_position(2,8);
// Formet the display sprintf(cText, "%4d", ulVal);
// Write ADC value to LCD LCD_Write_string(&cText[0]);
// Pavza pause(); }
Thank you for helping!
Jure
