no flying leads, no shorts, no static - suddenly my device behaves this way
is this something I could have done
is there a cure,
I build a new project for check - same error
from manual: Device could not be powered up Debug block on the device could not be powered. Debug block on the target is not working properly. Mainly caused by target problems: debug block not powered and clocked properly.
http://www.keil.com/forum/63223
