Return instruction of CALLA
Hi All
I'm looking for an issue in a code written in C and I think it might be due to the compiler. For this SW I'm using c166 V3.05a (an old legacy code).
The compiler calls one function with CALLA instruction but the return instruction is RETS (I think should be RET).
I think that this cause a spurious value into the stack that in some case create error in the other part of the code.
The code that cause this is like
BYTE* funct();
BYTE * p_a;
BYTE funct_val();
*(p_a = funct()) = funct_val();
The compiler call funct() with a CALLA instruction (and the function return with RETS)
if i change it with
p_a = funct()
*(p_a) = funct_val();
funct() is called with CALLS (and the function return with RETS)
