Hi everyone I have problem with my linker script, i want to setup position of my own vector table, stack and heap by myself using C++. Everything seems to be ok until program invoke fun.blink() function and try to heck value of pin_state variable, when this is happen program immediately jump to HardFault_Handler_IRQ.
Im using ARM v6.12 compiler
compiler control string: -xc -std=c99 --target=arm-arm-none-eabi -mcpu=cortex-m3 -c -fno-rtti -funsigned-char -fshort-enums -fshort-wchar -D__EVAL -gdwarf-3 -O0 -ffunction-sections -Wno-packed -Wno-missing-variable-declarations -Wno-missing-prototypes -Wno-missing-noreturn -Wno-sign-conversion -Wno-nonportable-include-path -Wno-reserved-id-macro -Wno-unused-macros -Wno-documentation-unknown-command -Wno-documentation -Wno-license-management -Wno-parentheses-equality -I . -I./RTE/_STM32F103VB -IC:/Keil_v5/ARM/PACK/Keil/STM32F1xx_DFP/2.3.0/Device/Include -IC:/Keil_v5/ARM/CMSIS/Include -D__UVISION_VERSION="526" -DSTM32F10X_MD -DUSE_STDPERIPH_DRIVER -DSTM32F10X_MD -o ./Objects/*.o -MD
linker control string: --cpu Cortex-M3 *.o --strict --scatter ".\linker_script.sct" --summary_stderr --info summarysizes --map --load_addr_map_info --xref --callgraph --symbols --info sizes --info totals --info unused --info veneers --list ".\Listings\TEST_03.map" -o .\Objects\TEST_03.axf
main.cpp --------------- class fun{ public: fun(uint8_t _pin):pin{_pin},pin_state{0}{ } void blink(void){ if(pin_state) {pin_state=0;GPIOB->ODR |=(1<<pin);} else {pin_state=1;GPIOB->ODR &=~(1<<pin);} }; uint8_t pin; bool pin_state; }; fun fun_1(8); int main(void){ RCC_Config(); GPIO_Config(); NVIC_Config(); volatile unsigned long int i; while(1){ for(i=0;i< 0x250000ul;i++); fun_1.blink(); }; } void Reset_Handler_IRQ(void){ __ASM( "LDR R0, = 0x20000000 ;" "LDR R1, = 0x20000400 +0x200 ;" "LDR R2, = (0x20000000 + 0x200) ;" "LDR R3, = (0x20000400);" ); main(); } void NMI_Handler_IRQ(void){}; void HardFault_Handler_IRQ(void){}; void MemManage_Handler_IRQ(void){}; void BusFault_Handler_IRQ(void){}; void UsageFault_Handler_IRQ(void){}; void SVC_Handler_IRQ(void){}; void DebugMon_Handler_IRQ(void){}; void PendSV_Handler_IRQ(void){}; void SysTick_Handler_IRQ(void){}; const uint32_t __initial_sp=0x20000400; const uint32_t Reset_Handler=(uint32_t)Reset_Handler_IRQ; const uint32_t NMI_Handler=(uint32_t)NMI_Handler_IRQ; const uint32_t HardFault_Handler=(uint32_t)HardFault_Handler_IRQ; const uint32_t MemManage_Handler=(uint32_t)MemManage_Handler_IRQ; const uint32_t BusFault_Handler=(uint32_t)BusFault_Handler_IRQ; const uint32_t UsageFault_Handler=(uint32_t)UsageFault_Handler_IRQ; const uint32_t SVC_Handler=(uint32_t)SVC_Handler_IRQ; const uint32_t DebugMon_Handler=(uint32_t)DebugMon_Handler_IRQ; const uint32_t PendSV_Handler=(uint32_t)PendSV_Handler_IRQ; const uint32_t SysTick_Handler=(uint32_t)SysTick_Handler_IRQ; extern "C" const uint32_t vector_table[16] __attribute__((section("vectors")))={ __initial_sp, // Top of Stack Reset_Handler, // Reset Handler NMI_Handler, // NMI Handler HardFault_Handler, // Hard Fault Handler MemManage_Handler, // MPU Fault Handler BusFault_Handler, // Bus Fault Handler UsageFault_Handler, // Usage Fault Handler 0, // Reserved 0, // Reserved 0, // Reserved 0, // Reserved SVC_Handler, // SVCall Handler DebugMon_Handler, // Debug Monitor Handler 0, // Reserved PendSV_Handler, // PendSV Handler SysTick_Handler // SysTick Handler };
linker_script.sct -------------- LR_IROM2 0x08000000 0x00001000 { ; load region size_region VECT 0x08000000 0x00000040{ *.o (vectors, +First) } ER_IROM1 +0 0x00001000 { ; load address = execution address *.o *(InRoot$$Sections) .ANY (+RO) .ANY (+XO) .ANY (+ZI) } ARM_LIB_STACK 0x20000400 EMPTY -0x200 ; Stack region growing down { } ARM_LIB_HEAP 0x20000000 EMPTY 0x200 ; Heap region growing up { } }
__main is a part of Arm C library, as detailed here www.keil.com/.../armclang_intro_asa1505906246660.htm
Ok it seems you have right, but im curious what exactly is __main where i can find it's implementation? where it come from?
Should perhaps be calling __main to have some hope of initializing the statics and constructors.
