Hi everybody,
Can any one help me how to determine the DAC voltage output. I m using C8051F126. In the datasheet they indicate this information : Each DAC has an output swing of 0V to (VREF-1LSB) for a corresponding input code range of 0x000 to 0xFFF. My voltage Ref for the DAC is equal to 1.65V and the DAC is 12bits. So for example if DAC0H = 0X08 and DAC0L=0x00. What is the voltage output of the DAC ?
I thank you for your support.
Best regards,
Geek12.
