hello,
I'm creating a parser to parse through data from UART. I managed to get it working with VS code and gcc but had a hard time implementing it in my initial keil project. Here's my code:
typedef struct device { int n; char MAC[12]; char name[20]; }device; void readlines(char *str,device* t) { const char s[5] = "\r\n"; char *token; int i = 0; token = strtok(str, s); while (token != NULL) { sscanf(token, "OK+DIS%d:%12cOK+NAME:%[^\0]\r\n", &t[i].n, t[i].MAC, t[i].name); token = strtok(NULL, s); i++; } }
%[^\0] is meant to include spaces in the t[i].name since sscanf consider \0 as a delimiter to the message, and %[^ ] doesn't work as intended. But I get always the same error unless I change %[^\0] by %[^ ] or something else. I have the <stdio.h> included by the way .Here's the error message: Error: L6218E: Undefined symbol _scanf_wctomb (referred from application.o).
Best regards.
No. '\0' delimits the format string, like it would any string in a C program. sscanf never sees it. So your input format is actually "%[^", which makes no sense at all. I suspect it's bad enough to qualify for the ultimate harsh judgement by the C standard: "causes undefined behaviour". As such, a linker error is actually one of the nicer result you could have got.
That's because it expresses the exact opposite of what you intended: it includes everything except for spaces.
