Hi everyone,
I'm a begginner and i'm trying to display a "DO" on my STM32L-Discovery board (STM32L152). In order to do so, I tried to connect the button to the pin PA11. Nevertheless, it doesn't work.
Here is my code :
int main(void) /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_LCD_Init(); MX_DAC_Init(); /* USER CODE BEGIN 2 */ BSP_LCD_GLASS_Init(); BSP_LCD_GLASS_BarLevelConfig(0); BSP_LCD_GLASS_Clear(); // PA11 as digital input(00) GPIOA->PUPDR &= ~(1 << (11*2 +1)); GPIOA->PUPDR |= (1 << (11*2)); /* USER CODE END 2 */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ if ((GPIOA->IDR&(0X0000000B)==0)) { while ((GPIOA->IDR&0X0000000B)==0) { BSP_LCD_GLASS_DisplayString((uint8_t *)"DO"); wait(70000); } BSP_LCD_GLASS_Clear(); } /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ } <\pre> Does anyone have a idea to solve this problem ? Thanks in advance :)
So what debugging/testing/investigation have you done to find out where it's going wrong?
I tried the debug. Then, nothing happended. When I pressed the button, nothing appeared.
Perhaps try building some of ST's examples from the HAL libraries. See those work, and modify them to your needs.
Always a good plan!
And learn to use the debug tools on those examples.
www2.keil.com/.../learn
Support, examples, etc for the STM32L-DISCOVERY and 32L152CDISCOVERY kits here: www.st.com/.../32l152cdiscovery.html
ST have their own YouTube channel, with lots of STM32 learning material: www.youtube.com/.../UCjnmZw3h4XnpK3e5D2jvIGA
And learning site: www.st.com/.../stm32-education.html
See also: http://community.st.com/
