With UV4.exe the resource dialog fonts are a mixture of (mostly) "Microsoft Sans Serif" and "MS Shell Dlg". "Microsoft Sans Serif" expands to about 50% larger than "MS Shell Dlg" and so the dialog gets truncated or the right half is not visible. I can't edit the debugger settings without editing the uv4.exe resource and changing the font. This is on windows 7 with scaling set to 100%.
This is a big problem. I have to tab to the hidden buttons, but the tab order of the dialog is not consistent too.
Would agree that the resources should be consistent, but not had an issue with this over years of use.
Seems to be some combination of screen settings/resolutions,fonts and scaling options.
Don't expect uV4 to be developed further, consider just using an automated tool to change the resources/fonts to achieve the consistency desired.
Westonsupermare Pier said:Don't expect uV4 to be developed further
Despite its name, "uv4.exe" is the executable for uVision-5 - which is a current product.
Hallo Robert,
thanks for reporting this. Which MDK version are you using? The latest one, v5.28a? Since when do you have these problems?
I would suggest to contact our support via support.intl@keil.com so that the right people can take a look at this.
Kind regards,
Christopher
PS: Andy is right: although the executable is called uv4.exe, it is under full maintenance and is developed further ;)
