With UV4.exe the resource dialog fonts are a mixture of (mostly) "Microsoft Sans Serif" and "MS Shell Dlg". "Microsoft Sans Serif" expands to about 50% larger than "MS Shell Dlg" and so the dialog gets truncated or the right half is not visible. I can't edit the debugger settings without editing the uv4.exe resource and changing the font. This is on windows 7 with scaling set to 100%.
This is a big problem. I have to tab to the hidden buttons, but the tab order of the dialog is not consistent too.
Would agree that the resources should be consistent, but not had an issue with this over years of use.
Seems to be some combination of screen settings/resolutions,fonts and scaling options.
Don't expect uV4 to be developed further, consider just using an automated tool to change the resources/fonts to achieve the consistency desired.
Westonsupermare Pier said:Don't expect uV4 to be developed further
Despite its name, "uv4.exe" is the executable for uVision-5 - which is a current product.
