Hello All,
I'm having the same issue as was reported here - but this thread was seemingly unanswered:
http://www.keil.com/forum/58911/
I'm seeing this:
Error: L6200E: Symbol os_tmr multiply defined (by rt_timer.o and rtx_conf_cm5.o).
Before someone tells me to upgrade to the latest; for this project I'm using RTX v. 1.0 and the lib version is 4.79. I'm having to stay at these levels right now due to numerous issues.
I don't have control over what the IDE selects as the lib that gets linked in - and rt_timer.c is being linked in by that.
Also, the rtx_conf_cm5.c file is just a config file; there are no explicit os_tmr (rtx_tmr) functions in that.
Thanks In Advance, John W.
To All:
I think I may have found the issue here:
In RTX_CM_lib.h:
/* Legacy RTX User Timers not used */ #if 0 extern uint32_t os_tmr; uint32_t os_tmr = 0U; #endif
If I # define that out - I am no longer getting the error.
This seems to be some type of compatibility issue that should be known.
Regards, John W.
