I am executing fromelf with User After Build automation.
It wasn't a problem by specifying the absolute path of the executable in the past when only ARMCC was used.
After that my projects involve inter-mixture of compilers.
Therefore the need for dynamic path became relevant.
Would be nice if Keil adds Key Sequences to few important 'Currently used Compiler' Directories.
I know know $J points to the Include folder. So for my case, to access the bin folder I need to specify $J\..\bin\
It's not a problem, but just a suggestion.
ST
I vote for this. When you use the GCC as a compiler you can't even use $J.
