Hi guys, So I used an example of the HAL library to configure an input capture with a timer on a stm32f373vct6 microcontroller. Now I want to include this example in my project, but when I do so and try to build the compiler says : Error: L6218E: Undefined symbol HAL_TIM_IC_Init (referred from)
I properly included the stm32f3xx_hal.h library and the stm32f3xx_hal_conf.h but still it does not work. From previous thread(community.st.com/.../error-l6218e-undefined-symbol-haladcinit-referred-from-maino) I saw that you need to define some params. I went into the stm32f3xx_hal_conf.h library, and removed the ifdef condition for the stm32f3xx_hal_tim.h library but still it does not work.
Thank you for the help !
Hello Amine,
I suggest using the STM32Cubemx tool to generate your code.
You can launch it from with in the Keil uVision IDE:
www.keil.com/.../cubemx_proj.html
It should make sure that you aren't missing any helper functions or header files.
Here is a demo that is a little dated of using cubemx and keil
www.youtube.com/watch
Here is a more in depth video on using Cubemx
Hi Ron , Firstly thank you for you help. The point in my project was to not use the STM cube generator. I solved my problem! Thank you!
