I just migrated a project from Keil 3 to Keil 5 (C51 = V9.56.0.0 & LX51 4.66.66.0
I get the following (new) warnings:
*** WARNING L48: IGNORED RECURSIVE CALL CALLED: _SMBUS_SET_PACKET_DATA/SMBUS CALLER: SMBUS *** WARNING L48: IGNORED RECURSIVE CALL CALLED: SMBUS CALLER: _SMBUS_SET_PACKET_DATA/SMBUS
puzzle is that while there is a routine called smbus_set_packet_data there is no routine called smbus. In fact the routine is reproduced below:
static void smbus_set_packet_data(uint8_t pos, uint8_t val,uint8_t info) { smbus_packet[pos] = val; smbus_packet_info[pos] = info; }
What does the above warning indicate?
What exactly did the linker ignore? (Any calling sequence not included in the final binary?
thanks for the clarifications.
The manuals say it's to do with function pointers:
http://www.keil.com/support/man/docs/bl51/bl51_l48.htm
http://www.keil.com/support/man/docs/lx51/lx51_l48.htm
So is "smbus" the name of a function pointer ... ?
Or a Module (source file), rather than a "routine" ... ?
C51 (due to the hardware of the '51) has REAL problems with recursive and/or function pointers.
It takes a seasoned developer or 2 bottles of aspirin to make that work
unfortunately it is common for those that want to 'think PC' to throw both in
