Hello , I'm working on the stm8l microcontroller and trying to use its USART. I am getting a very peculiar problem. No matter what value I assign to the USART_DR register , it always takes the value 0xff even if I give char value or a int value. I am reading the DR register using the debugger of STVD. Is there a way to read TDR and RDR registers separately? My code is as follows:
# include "stm8l.h" # include "stm8s.h" unsigned int i = 0; unsigned int val = 0; strlen(const char *str) { const char *s; for (s = str; *s; ++s); return (s - str); } void clockinit(void) //16MHz internal clock enable { CLK_SWR = 0x01; CLK_ICKR = 0x00; CLK_ECKR = 0x00; CLK_DIVR = 0x00; CLK_PCKENR1 = 0xFF; CLK_PCKENR2 = 0xFF; } void usartinit(void) //usart initialisation (115200 , 8bit , no parity , 1 stop bit { char X; PC_DDR = 0x10; PC_CR1 = 0x10; PE_DDR = 0xff; PE_CR1 = 0xff; X = USART1_SR; X = USART1_DR; USART1_CR1 = 0x00; USART1_CR2 = 0x0C; USART1_CR3 = 0x0f; USART1_CR4 = 0x03; USART1_CR5 = 0x00; USART1_GTR = 0x00; USART1_PSCR = 0x00; USART1_BRR2 = 0x0A; USART1_BRR1 = 0x08; } void main() { char *z = "HELLO"; clockinit(); usartinit(); val = strlen(z); for (i = 0;i<val;i++) { USART1_DR = *z; while (USART1_SR_TXE == 0) { z++; } } }
This has nothing to do with Keil - Keil do not have any STM8 products.
You need to go to the ST forum:
community.st.com/.../stm8-mcus
Oh - you already have:
community.st.com/.../41634-usart-with-stm8l
