Hi all,
First: I am working on STM32F407 and I am using two iRAMs and one external SRAM with addresses: addr size iRAM1: 0x20000000 0x20000 iRAM2: 0x10000000 0x10000 RAM1: 0x60000000 0x200000
C compiler, linker,.... v5.03.0.76 toolchain MDK-ARM Professional version 4.74.0.0
Problem: After I created multiple connections from PC (TCP ethernet) to the device, program runs out of memory with ERR_SYS_ERR_MEM_ALLOC err. So I tried to increase size of Memory Pool by redefining macro MEM_SIZE from 2000 to 6000 but after this TCPnet does not call listener function.
I checked memory map and there is enough space (see net_config.o)
0x20000d78 0x0000d008 Zero RW 7444 .bss .\obj\mozekvof_line.o 0x2000dd80 0x00000010 Zero RW 16376 .bss .\obj\ui_stftpresponse.o 0x2000dd90 0x00008430 Zero RW 22795 .bss .\obj\net_config.o 0x200161c0 0x00000010 Zero RW 29126 .bss C:\Keil\ARM\RV31\LIB\TCP_CM3.lib(at_mem.o) 0x200161d0 0x00000038 Zero RW 29445 .bss C:\Keil\ARM\RV31\LIB\RTX_CM4.LIB(rt_task.o) 0x20016208 0x00000030 Zero RW 29933 .bss C:\Keil\ARM\RV31\LIB\RTX_CM4.LIB(rt_list.o) 0x20016238 0x00000060 Zero RW 30138 .bss C:\Keil\ARM\ARMCC\bin\..\lib\armlib\c_w.l(libspace.o)
What works well is to assign address of the static array mem_pool exactly but it is not good solution....
static U32 mem_pool[MEM_SIZE] __attribute__((section(".ARM.__at_0x200138b0"), zero_init));
What causes this error? How can I get rid of this without assigning random variable addresss?
