Compiling with change of package.
HELP pleeeese!
I have a board with an STM32f429IGT loosely copied from the STM32F29ZIT Discovery board.
If I compile the Keil STM32F429-Disco Emwin example (after changing display pins to suit) and then change the Device to the IGT version in Target set up, all works well.
If however I compile the project with the device set as an IGT, I get an SPI error (which I can mend) followed by a lock up in Gui_Init();
This does not change if I then go back to the ZIT version and recompile.
It appears, providing I only compile with the ZIT device set, followed by device change, it is fine.
Problem is that if I forget, I have to start again.
The only difference that I am aware of between the 2 devices is the program E2 memory (1M v 2M)and I do not believe that this program takes anywhere near 1 M
Any clues please!
