Using: uVision 5 *** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil\uVision5\ARM\ARMCC\Bin'
I'm trying to make a variable equal to a binary number, something like:
unsigned char Number = 0b00001111;
The IDE doesn't show any issues on the screen, but the compiler comes back with this error:
..\ZCU\source\code\Debug_rW.c(67): error: #19: extra text after expected end of number
How do I get round this?
Secondly, I which to view that "Number" in a watch window as a binary number, is this possible? I can only see Hex and Decimal as an option.
Many thanks for any input.
Regards, R
Did you try using the 'y' or 'Y' suffix?
See this link: http://www.keil.com/support/man/docs/uv4/uv4_db_exp_constants.htm
You would have to choose a different programming language - 'C' does not support binary literals in source code.
Nothing to do with Keil or ARM.
However, as noted, you can set the debugger to display in binary.
Well, it has, apparently, been added to the C++14 standard:
stackoverflow.com/.../difference-between-gcc-binary-literals-and-c14-ones
www.open-std.org/.../n3472.pdf
stackoverflow.com/.../why-doesnt-c-have-binary-literals
How do you do the above?
Many thanks.
Yes, doesn't work.
Thanks.
Did you not follow the link provided by Brandon Price ?
Yes, I have followed various links... the Suffix "y" or "Y" does not work.
Is there a way of showing a variable as binary in the watch window?
Show exactly what you actually did, and the results you got.
C Does not typically provide a way to enter Binary representation of a number, but you could write a macro to do this:
http://www.keil.com/support/docs/1156.htm
Or use the octal notation trick
http://www.keil.com/forum/21497/how-to-input-a-binary-number/
If you are using ARM Compiler 6, you can use ARM Assembly to write a Binary Literal:
developer.arm.com/.../numeric-literals
