Using: uVision 5 *** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil\uVision5\ARM\ARMCC\Bin'
I'm trying to make a variable equal to a binary number, something like:
unsigned char Number = 0b00001111;
The IDE doesn't show any issues on the screen, but the compiler comes back with this error:
..\ZCU\source\code\Debug_rW.c(67): error: #19: extra text after expected end of number
How do I get round this?
Secondly, I which to view that "Number" in a watch window as a binary number, is this possible? I can only see Hex and Decimal as an option.
Many thanks for any input.
Regards, R
You would have to choose a different programming language - 'C' does not support binary literals in source code.
Nothing to do with Keil or ARM.
However, as noted, you can set the debugger to display in binary.
Well, it has, apparently, been added to the C++14 standard:
stackoverflow.com/.../difference-between-gcc-binary-literals-and-c14-ones
www.open-std.org/.../n3472.pdf
stackoverflow.com/.../why-doesnt-c-have-binary-literals
