I'm playing around with scatter-loading in Keil 5.25 with armcc compiler. Now I have a dummy project that allocates stack and heap in 'default' startup assembly file:
Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; <h> Heap Configuration ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB
I'm trying to use scatter file to place stack and heap at some specific memory regions. I do it like this:
LR_IROM1 0x8000000 0x4000 { ; load region size_region ER_IROM1 0x8000000 0x4000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } ARM_LIB_STACK 0x20000000 { *(STACK) } ARM_LIB_HEAP 0x20004000 { *(HEAP) } RW_IRAM1 0x20006000 { *(+RW +ZI) } }
And in main I call malloc to allocate some memory.
When I build the project, linker gives me this warning: "./dummy.sct(34): warning: L6329W: Pattern *(HEAP) only matches removed unused sections."
But I use malloc, so I should be using heap memory. In debugger I can see that memory that I allocated by malloc was already taken by some global variable, which I presume means that heap region is indeed removed by the linker.
But why is it happening? What am I doing wrong?
I was able to force linker not to remove heap by --keep option but I still want to know what is wrong.
