shifting bits in multiple bytes array
Hello All,
I have non-standart function that shifting bits in multi bytes.
Syntax:
 shift_left (address, bytes, value);
Parameters:
 address is a pointer to memory.
 bytes is a count of the number of bytes to work with
 value is a 0 to 1 to be shifted in.
Returns:
 0 or 1 for the bit shifted out
Function:
 Shifts a bit into an array or structure. The address may be an array identifier or an address to a structure (such as &data). Bit 0 of the lowest byte in RAM is treated as the LSB
Any idea how to implement efficient "C" code for 8051?
  • Let's just have that "Function" description so that we can read it without having to scroll off miles to the right:
    Function:
    "Any idea how to implement efficient 'C' code for 8051?"
    So what have you tried?
    Where are you stuck?
    I would suggest that the way to approach is to start with a general approach - don't worry about "efficiency" (whatever that means here) or 8051 specifics.
    Draw out on paper what needs to happen.
    Implement that using standard 'C' features, operators, etc.
    Test on a PC.
    Only when you have something that works in general, move on to think about what specific features the 8051 hardware and Keil C51 tools have that could optimise this.
