After solving a series of errors communicating with the LPC824M201JHI33 the error invalid Rom table started occuring, even though the board responds to code sent before the first occurrence of said error and none of the solutions we found worked. please help.
Hi Nuno,
can you put the microcontroller into an ISP mode by boot pins, and try then?
Best regards, Milorad
LPC-LINK2 CMSIS-DAP V5.182
Which particular CMSIS-DAP debugger are you using?
Everytime I try to download to flash the error shows up, I'm using the CMSIS-DAP debugger and I´ve tried changing the debug settings to no avail.
How are you observing that?
