Keil: What is node used for
Hello
Whenever I open a uVision project, the <nTsel> node gets updated in the *.uvoptx file.
For instance,
<nTsel>0</nTsel> becomes <nTsel>4</nTsel>
What's the purpose of the node and can I set it from the project file itself?
Regards
Pavel
  • nTsel is an internal index that identifies the target driver
    selection such as Ulink-Pro, Ulink-Plus, Jlink and others.
    Once you change the target driver selection via Options-for-Target - Debug,
    then selecting another target driver using the target driver combo
    then 'nTsel' will change.
