Hi all,
Im using LPC2136 and i want to use the UART0 serial port interrupt to receive data but it does not work. configure all the registers and I do not see any jump towards the interruption when receiving the data in U0RBR.
--------------------------------------------------------- int main(void) { int x, y, dx, dy; init_PLL(); SPI_init(); Serial0_init(); init_gpiox(); UART0_Interrupt_EN(); while(!(U0LSR&0x20)); //THRE = 0 stay here U0THR= 'T'; while(!(U0LSR&0x20)); //THRE = 0 stay here U0THR= 'E'; while(!(U0LSR&0x20)); //THRE = 0 stay here U0THR= 'S'; while(!(U0LSR&0x20)); //THRE = 0 stay here U0THR= 'T'; IO0SET |= 0x00000080; delay(); IO0CLR |= 0x00000080; while(1); }
--------------------------------------------------------------------- it is not jumping here!!!
void UART0Handler (void) __irq { while(!(U0LSR & 0x01)){}; //RDR = 0 stay here rxdat = U0RBR; IO0SET |= 0x00000080; delay(); IO0CLR |= 0x00000080; VICVectAddr= 0x00000000; } --------------------------------------------------------------------------- void UART0_Interrupt_EN(void) { VICIntSelect = 0x00000000; VICVectAddr6 = (unsigned) UART0Handler; //Vector 6 VICVectCntl6 = 0x00000020 | 6; //select UART0 VICIntEnable = 0x00000040; //interrupt } ---------------------------------------------------- startup.s configuration
Vectors LDR PC, Reset_Addr LDR PC, Undef_Addr LDR PC, SWI_Addr LDR PC, PAbt_Addr LDR PC, DAbt_Addr NOP ; Reserved Vector ; LDR PC, IRQ_Addr LDR PC, [PC, #-0x0FF0] ; Vector from VicVectAddr LDR PC, FIQ_Addr
Reset_Addr DCD Reset_Handler Undef_Addr DCD Undef_Handler SWI_Addr DCD SWI_Handler PAbt_Addr DCD PAbt_Handler DAbt_Addr DCD DAbt_Handler DCD 0 ; Reserved Address IRQ_Addr DCD IRQ_Handler FIQ_Addr DCD FIQ_Handler
Undef_Handler B Undef_Handler SWI_Handler B SWI_Handler PAbt_Handler B PAbt_Handler DAbt_Handler B DAbt_Handler IRQ_Handler B IRQ_Handler FIQ_Handler B FIQ_Handler
