Hi keil, Every time,resource consumption is very high leading to the running speed of computer is slow when keil is compiling ARM project.I want to know the reason? Best regards, Frank
Err ... maybe because the computer is actually busy building your project as fast as it can.
If you have Browse Information generation checked it can cause your computer to slow quite a bit. Try turning it off and see if that makes it seem more reasonable.
